Salta al contenuto principale
Lenovo Yoga C930-13IKB Coolant Fan Replacement
Cosa ti serve
  1. Lenovo Yoga C930-13IKB Coolant Fan Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Coolant Fan Replacement: passo 2, immagine 1 di 2 Lenovo Yoga C930-13IKB Coolant Fan Replacement: passo 2, immagine 2 di 2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Coolant Fan Replacement: passo 3, immagine 1 di 2 Lenovo Yoga C930-13IKB Coolant Fan Replacement: passo 3, immagine 2 di 2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Coolant Fan Replacement, Coolant Fans: passo 4, immagine 1 di 1
    • Remove the four 3 mm Phillips #0 screws from the fan assembly.
  5. Lenovo Yoga C930-13IKB Coolant Fan Replacement: passo 5, immagine 1 di 1
    • Remove the four 2 mm Phillips #00 screws from the fans themselves.
  6. Lenovo Yoga C930-13IKB Coolant Fan Replacement: passo 6, immagine 1 di 1
    • Unscrew the three 3 mm Phillips #0 screws on the heatsink.
  7. Lenovo Yoga C930-13IKB Coolant Fan Replacement: passo 7, immagine 1 di 2 Lenovo Yoga C930-13IKB Coolant Fan Replacement: passo 7, immagine 2 di 2
    • Use a plastic opening tool to remove the two small, white power cable connectors for each of the two fans.
  8. Lenovo Yoga C930-13IKB Coolant Fan Replacement: passo 8, immagine 1 di 1
    • Gently lift the fan assembly out of the laptop.
    • Be sure to clean and reapply thermal paste to the heatsink during reassembly.
Conclusione
To reassemble your device, follow these instructions in reverse order. Remember to apply fresh thermal paste to the heatsink during reassembly.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 42
Tutti i Tempi: 1,518
