Salta al contenuto principale
Lenovo Yoga 920-13IKB Screen Replacement
Cosa ti serve
  1. Lenovo Yoga 920-13IKB Screen Replacement, Screen: passo 1, immagine 1 di 3 Lenovo Yoga 920-13IKB Screen Replacement, Screen: passo 1, immagine 2 di 3 Lenovo Yoga 920-13IKB Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Rotate the device into tablet mode so the device’s screen is facing up.
  2. Lenovo Yoga 920-13IKB Screen Replacement: passo 2, immagine 1 di 3 Lenovo Yoga 920-13IKB Screen Replacement: passo 2, immagine 2 di 3 Lenovo Yoga 920-13IKB Screen Replacement: passo 2, immagine 3 di 3
    • Pry the metal cover up from the bottom of the screen with the iFixit Opening Tool to reveal the corners of the white adhesive strip.
    • Pull the metal cover off the device until it's completely free.
    • Clean off the old adhesive and straighten the metal cover when reassembling.
    • Use a new adhesive when reassembling.
    • Avoid bending the metal cover to prevent damage to the device.
    • If you’re really struggling, you may pry from the opposite side, but be careful not to damage the screen or metal cover.
  3. Lenovo Yoga 920-13IKB Screen Replacement: passo 3, immagine 1 di 2 Lenovo Yoga 920-13IKB Screen Replacement: passo 3, immagine 2 di 2
    • Remove the eight 3mm Phillips #000 screws that were below the metal cover to loosen the screen.
  4. Lenovo Yoga 920-13IKB Screen Replacement: passo 4, immagine 1 di 3 Lenovo Yoga 920-13IKB Screen Replacement: passo 4, immagine 2 di 3 Lenovo Yoga 920-13IKB Screen Replacement: passo 4, immagine 3 di 3
    • Pull out the white adhesives using the iFixit Tweezers.
    • Roll the tape around the iFixit Tweezers to remove successfully.
  5. Lenovo Yoga 920-13IKB Screen Replacement: passo 5, immagine 1 di 1
    • Pry up the screen with the iFixit Opening Tool.
  6. Lenovo Yoga 920-13IKB Screen Replacement: passo 6, immagine 1 di 2 Lenovo Yoga 920-13IKB Screen Replacement: passo 6, immagine 2 di 2
    • Lift the screen with your hands and place the the screen face down, keeping the device in the same location.
  7. Lenovo Yoga 920-13IKB Screen Replacement: passo 7, immagine 1 di 1
    • Flip up the black tab on the connector at the top of the screen with the iFixit Opening Tool.
  8. Lenovo Yoga 920-13IKB Screen Replacement: passo 8, immagine 1 di 1
    • Use the iFixit Tweezers to remove the ribbon cable from the connector.
  9. Lenovo Yoga 920-13IKB Screen Replacement: passo 9, immagine 1 di 1
    • Flip up the black tab on the smallest connector at the bottom of the screen with the iFixit Opening Tool.
  10. Lenovo Yoga 920-13IKB Screen Replacement: passo 10, immagine 1 di 1
  11. Lenovo Yoga 920-13IKB Screen Replacement: passo 11, immagine 1 di 1
    • Flip up the thick black cable at the bottom of the screen with your thumb.
    • Use the iFixit Opening Tool to lift up the brass tab to free up the cable.
  12. Lenovo Yoga 920-13IKB Screen Replacement: passo 12, immagine 1 di 1
    • Remove the ribbon cable from the connector to detach the screen from the device.
Conclusione
Cal Poly, Team S2-G3, White Winter 2019 Membro di Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Membri
29 Guide realizzate
5 Commenti
Does this also appy to the Yoga 910-13IBK?
Tony Salazar - Replica
Alyssa, I am about to tackle this job to replace a cracked screen - I greatly appreciate your guide. In step 2 you recommend using new adhesive. What adhesive is recommended exactly?
Bradley Buege - Replica
See this youtube video from Lenovo on LCD tape, how to find what kind, how to remove it, and how to reapply it.
https://www.youtube.com/watch?v=EeUM312_...
Robert -
You missed the camera transfer step. I completed the screen replacement only to find no camera for Zoom. Then realized the this procedure didn’t cover the camera transfer.
ddurbin1 - Replica
Ok, 15 minutes to complete this is ridiculous. A seasoned person couldn't do this in 15 minutes, especially when removing and replacing adhesive, etc. That must be a typo.
Syber Geek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 66
Tutti i Tempi: 5,212
