Salta al contenuto principale
Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement
Cosa ti serve
  1. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: passo 1, immagine 1 di 2 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: passo 1, immagine 2 di 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 2, immagine 1 di 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 2, immagine 2 di 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 2, immagine 3 di 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: passo 3, immagine 1 di 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: passo 3, immagine 2 di 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: passo 3, immagine 3 di 3
    • Remove the four 5mm Phillips #00 screws that hold the battery in place.
  4. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 4, immagine 1 di 2 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 4, immagine 2 di 2
    • Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
    • The wire grouping is located underneath the thin flap near the center of the battery.
    • Do not lift the battery out before disconnection from the motherboard to prevent shortages or damage.
  5. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 5, immagine 1 di 1
    • Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
  6. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
  7. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Fingerprint Sensor: passo 7, immagine 1 di 1
    • Remove the 3mm Phillips #00 Screw to loosen the sensor.
  8. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 8, immagine 1 di 1
    • Lift up the cover on the fingerprint sensor using the iFixit Opening Tool and remove the cover from the sensor.
  9. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 9, immagine 1 di 1
    • Flip up the cable connector tab using the iFixit Opening Tool to release the ribbon wire.
  10. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 10, immagine 1 di 1
    • Unplug the ribbon wire from the sensor to completely free the sensor.
  11. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: passo 11, immagine 1 di 1
    • Lift the fingerprint sensor with the iFixit Opening Tool and remove it from the device.
Conclusione
Cal Poly, Team S2-G3, White Winter 2019 Membro di Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Membri
29 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 569
