Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Follow this guide to replace the fingerprint reader in your Lenovo Yoga 910-13IKB. If you have ensured that the finger you are trying to sign in with has been properly registered and the reader is clean of any grease or debris, but the reader still fails to correctly recognize your finger, it may need to be replaced. While this replacement is one of the longer ones in terms of time for this device, it is still quick and easy to do, requiring only a JIS #00 screwdriver.
Parti
Nessuna parte specificata.
  1. Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten 3 mm Phillips screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Remove the four 3 mm Phillips screws holding the battery in place.
    • Remove the four 3 mm Phillips screws holding the battery in place.
  3. Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. Pull parallel to the battery, not straight up. Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. APRI TUTTE LE SCHEDE
    Kit espansione RAM per Mac
    Acquista Kit
    Abbastanza RAM
    Per tutte le schede
    Acquista Kit
  5. Remove the one 3mm JIS #00 screw on the right side of the silver component. Remove the one 3mm JIS #00 screw on the right side of the silver component.
    • Remove the one 3mm JIS #00 screw on the right side of the silver component.
  6. Gently pull up on the ribbon cable to detach it from the metal housing. Gently pull up on the ribbon cable to detach it from the metal housing.
    • Gently pull up on the ribbon cable to detach it from the metal housing.
  7. Lift the metal housing out and set it aside. This component holds the reader in place.
    • Lift the metal housing out and set it aside. This component holds the reader in place.
    • The left side of the component is tucked under the lip of the computer, so lift from the right side of the component.
  8. Remove the fingerprint reader from its place.
    • Remove the fingerprint reader from its place.
Conclusione
Nikki Sorfleet
Membro da: 23/01/2020
139 Reputazione
1 Guida realizzata
Cal Poly, Team S1-G5, White Winter 2020 Membro di Cal Poly, Team S1-G5, White Winter 2020
CPSU-WHITE-W20S1G5
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 109
