Salta al contenuto principale
Lenovo Yoga 910-13IKB Bottom Panel Replacement
Cosa ti serve
  1. Lenovo Yoga 910-13IKB Bottom Panel Replacement, Bottom Panel: passo 1, immagine 1 di 2 Lenovo Yoga 910-13IKB Bottom Panel Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 2, immagine 1 di 1
    • Remove all 4 screws attached to the battery with a small Phillips head screwdriver.
    • Each screw on the back is M2 x 1.7mm
    • After the screws are taken out, remove the battery.
  3. Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 3, immagine 1 di 1
    • Remove all 6 screws attached to the trackpad with a small Phillips head screwdriver.
    • Detach the ribbon cable connected to the trackpad using a wedge device.
    • Remove the trackpad using a wedge device
  4. Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 4, immagine 1 di 1
    • Remove all 6 screws attached to the USB ports on both sides of the device with a small Philips head screwdriver.
    • Detach both ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 5, immagine 1 di 3 Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 5, immagine 2 di 3 Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 5, immagine 3 di 3
    • Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
  6. Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 6, immagine 1 di 3 Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 6, immagine 2 di 3 Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 6, immagine 3 di 3
    • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
    • Remove the back connector strip using a wedge device to pry it off of the device
    • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
81.767 Reputazione
200 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,542
