Salta al contenuto principale
Lenovo Yoga 900-13ISK Speakers Replacement
Cosa ti serve
  1. Lenovo Yoga 900-13ISK Speakers Replacement, Back Cover: passo 1, immagine 1 di 2 Lenovo Yoga 900-13ISK Speakers Replacement, Back Cover: passo 1, immagine 2 di 2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Speakers Replacement: passo 2, immagine 1 di 3 Lenovo Yoga 900-13ISK Speakers Replacement: passo 2, immagine 2 di 3 Lenovo Yoga 900-13ISK Speakers Replacement: passo 2, immagine 3 di 3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Speakers Replacement, Battery: passo 3, immagine 1 di 3 Lenovo Yoga 900-13ISK Speakers Replacement, Battery: passo 3, immagine 2 di 3 Lenovo Yoga 900-13ISK Speakers Replacement, Battery: passo 3, immagine 3 di 3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Speakers Replacement: passo 4, immagine 1 di 3 Lenovo Yoga 900-13ISK Speakers Replacement: passo 4, immagine 2 di 3 Lenovo Yoga 900-13ISK Speakers Replacement: passo 4, immagine 3 di 3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Speakers Replacement, Speakers: passo 5, immagine 1 di 3 Lenovo Yoga 900-13ISK Speakers Replacement, Speakers: passo 5, immagine 2 di 3 Lenovo Yoga 900-13ISK Speakers Replacement, Speakers: passo 5, immagine 3 di 3
    • Use a pair of blunt nose tweezers or your fingers to pull out the speaker cable from the connector on the lower portion of the daughterboard on the left.
  6. Lenovo Yoga 900-13ISK Speakers Replacement: passo 6, immagine 1 di 3 Lenovo Yoga 900-13ISK Speakers Replacement: passo 6, immagine 2 di 3 Lenovo Yoga 900-13ISK Speakers Replacement: passo 6, immagine 3 di 3
    • Remove the four 2.4 mm Phillips #00 screws from the speakers on either side of the case. (two screws per speaker)
  7. Lenovo Yoga 900-13ISK Speakers Replacement: passo 7, immagine 1 di 3 Lenovo Yoga 900-13ISK Speakers Replacement: passo 7, immagine 2 di 3 Lenovo Yoga 900-13ISK Speakers Replacement: passo 7, immagine 3 di 3
    • Lift up the speaker on the right and start unwinding the cable from the hooks.
    • Thread the right speaker underneath the trackpad ribbon cable.
  8. Lenovo Yoga 900-13ISK Speakers Replacement: passo 8, immagine 1 di 1
    • Continue unwinding the speaker cables from the hooks until the entire assembly is free from the case.
Conclusione
Austin Blakely
Membro da: 03/11/19
19.389 Reputazione
53 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
16.562 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 503
