Introduzione
This repair guide will demonstrate the process of removing the back cover for the Lenovo Yoga 900-13ISK laptop. The bottom case is responsible for keeping dust and debris from interfering with the internal componentry of the laptop. If the bottom of your laptop case has been dented or damaged, replacing the cover will keep your components safe.
Removing the back cover will also allow you to access the inside of the Lenovo Yoga 900 in the case that you need to repair or replace a component, and is the first step in most repairs for this device.
Be sure to unplug and completely turn off your device before you start working.
Cosa ti serve
Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
