Salta al contenuto principale
Lenovo Yoga 730-13IKB Back Case Replacement
Cosa ti serve
  1. Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: passo 1, immagine 1 di 3 Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: passo 1, immagine 2 di 3 Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: passo 1, immagine 3 di 3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Back Case Replacement: passo 2, immagine 1 di 3 Lenovo Yoga 730-13IKB Back Case Replacement: passo 2, immagine 2 di 3 Lenovo Yoga 730-13IKB Back Case Replacement: passo 2, immagine 3 di 3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Back Case Replacement: passo 3, immagine 1 di 1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
Conclusione
Colin Reay
Membro da: 01/23/20
848 Reputazione
5 Guide realizzate
Cal Poly, Team S1-G1, White Winter 2020 Membro di Cal Poly, Team S1-G1, White Winter 2020
CPSU-WHITE-W20S1G1
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,006
