Salta al contenuto principale
Lenovo Yoga 720-15IKB Speakers Replacement
Cosa ti serve
  1. Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: passo 1, immagine 1 di 3 Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: passo 1, immagine 2 di 3 Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Speakers Replacement: passo 2, immagine 1 di 2 Lenovo Yoga 720-15IKB Speakers Replacement: passo 2, immagine 2 di 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: passo 3, immagine 1 di 3 Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: passo 3, immagine 2 di 3 Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: passo 3, immagine 3 di 3
    • Here are the speakers for this device.
    • Pull the right speaker straight up and remove it from the computer.
    • As you remove the speaker, make sure to also carefully pull the wire connected to the speaker out along with the speaker.
  4. Lenovo Yoga 720-15IKB Speakers Replacement: passo 4, immagine 1 di 1
    • Remove the left speaker similarly to how the right speaker was removed.
  5. Lenovo Yoga 720-15IKB Speakers Replacement: passo 5, immagine 1 di 1
    • Unplug the speaker by firmly pulling the wire out of the socket.
Conclusione
Jeremy Kostel
Membro da: 01/23/20
249 Reputazione
2 Guide realizzate
Cal Poly, Team S19-G3, White Winter 2020 Membro di Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Membri
25 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 25
Tutti i Tempi: 450
