Salta al contenuto principale
Lenovo Yoga 720-15IKB SSD Replacement
Cosa ti serve
  1. Lenovo Yoga 720-15IKB SSD Replacement, Bottom Cover: passo 1, immagine 1 di 3 Lenovo Yoga 720-15IKB SSD Replacement, Bottom Cover: passo 1, immagine 2 di 3 Lenovo Yoga 720-15IKB SSD Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB SSD Replacement: passo 2, immagine 1 di 2 Lenovo Yoga 720-15IKB SSD Replacement: passo 2, immagine 2 di 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB SSD Replacement, SSD: passo 3, immagine 1 di 1
    • Remove the one JIS #1 screw holding the SSD.
  4. Lenovo Yoga 720-15IKB SSD Replacement: passo 4, immagine 1 di 2 Lenovo Yoga 720-15IKB SSD Replacement: passo 4, immagine 2 di 2
    • Tilt the SSD away from the screw hole.
    • Pull out the SSD away from the socket it is plugged into.
Conclusione
Altre 3 persone hanno completato questa guida.
Jeremy Kostel
Membro da: 01/23/20
249 Reputazione
2 Guide realizzate
Cal Poly, Team S19-G3, White Winter 2020 Membro di Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Membri
25 Guide realizzate
Un commento
The M.2 drive shown as a replacement part, at the time I replaced mine, was an Corsair M.2 drive with a SATA interface. My machine would not boot with this drive. I looked up the original drive on the internet and it was an Intel M.2 NVMe drive. I bought a new M.2 NVMe drive and it works find. I guess the disk controller in my laptop does not recognize the M.2 with a SATA interface. Maybe something they changed in the middle of the product line. Anyway be sure to check which drive you have before you buy the replacement. Rest of the information great.
John Pritchard - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 53
Tutti i Tempi: 4,476
