Introduzione
This guide shows you how to replace the Lenovo Yoga 720 15-IKB (88YG7000828) RAM. This laptop is very similar to the Lenovo Yoga 720 13-inch , the Yoga 710, and the Yoga 730. The RAM replacement for all of these models will be similar. The RAM stands for Random Access Memory, and is the computer’s short-term digital storage. The RAM is usually durable and rarely needs to be replaced.
Strumenti
Parti
Nessuna parte specificata.
Power off the device before starting.
Flip the device over with the hinges facing away from you.
Remove seven 5.0 mm Torx T5 screws.
Remove three 9.5 mm Torx T5 screws.
To reassemble your device, follow these instructions in reverse order. Make sure to align the RAM cover with the tabs when popping it back on.
