Salta al contenuto principale
Lenovo Yoga 720-15IKB RAM Replacement
Cosa ti serve
  1. Lenovo Yoga 720-15IKB RAM Replacement, Bottom Cover: passo 1, immagine 1 di 3 Lenovo Yoga 720-15IKB RAM Replacement, Bottom Cover: passo 1, immagine 2 di 3 Lenovo Yoga 720-15IKB RAM Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB RAM Replacement: passo 2, immagine 1 di 2 Lenovo Yoga 720-15IKB RAM Replacement: passo 2, immagine 2 di 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB RAM Replacement, RAM: passo 3, immagine 1 di 2 Lenovo Yoga 720-15IKB RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Use your fingers to pry the RAM cover loose and remove it.
    • If you are having trouble prying the cover loose with your fingers, use a plastic opening tool.
    • When refitting the RAM cover, make sure that the cover maintains the same orientation and lines up with the tabs surrounding the RAM.
  4. Lenovo Yoga 720-15IKB RAM Replacement: passo 4, immagine 1 di 2 Lenovo Yoga 720-15IKB RAM Replacement: passo 4, immagine 2 di 2
    • Push outwards on the levers holding the short edges of the RAM in place. This will release the RAM.
    • Gently pull the RAM out, diagonally up and away from the socket.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure to align the RAM cover with the tabs when popping it back on.
Altre 2 persone hanno completato questa guida.
Shaina Bagri
Membro da: 01/23/20
447 Reputazione
2 Guide realizzate
Cal Poly, Team S19-G3, White Winter 2020 Membro di Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Membri
25 Guide realizzate
3 Commenti
I noticed that my Yoga 720 had the same memory as my 2017 iMac 27 inch. I had 2 32Gb and 2 16GB chips. So I tested both and they worked. I was able to get the machine up to 40gb of RAM. The usable RAM was reported to be 39.8GB usable.
George - Replica
This was the memory module I put into the Yoga 720.
A-Tech 32GB DDR4 2666MHz PC4-21300 (PC4-2666V) CL19 SODIMM 2Rx8 1.2V 260-Pin Non-ECC SO-DIMM Laptop Notebook RAM Memory Module
https://a.co/d/9YRnrXE
George - Replica
Thanks for this info!
Mara But - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 75
Tutti i Tempi: 3,932
