Introduzione
This guide will show you how to replace the speakers.
  1. Start by flipping the device over so that you see the screws.
    • Start by flipping the device over so that you see the screws.
    • Remove 7 Torx T5 short screws.
    • Remove 3 Torx T5 long screws.
    • starting from the USB port use your opening tool to gently pry up the case.
      • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the orders the arrows show.
      • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
    • Lift the case from the bottom side. NOT the side with the hinges.
      • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
    • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
      • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
    • Remove 4 J1 Philips screws.
    • Remove 1 J1 philips screw
      • Do not mix these screws up, as if you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
    • slightly lift the battery using your plastic opening tool.
      • Do not lift the battery out all the way, as it is still connected to the motherboard.
      • Do NOT puncture or deform the battery or it may catch fire or even explode.
    • Pull the battery towards you until the wire is accessible.
    • gently tug and wiggle on the wire until it pops out.
    • Remove the battery.
    • Disconnect the speakers.
    • Remove the left speaker.
    • Remove the Adhesive.
      • Use this pull tab to remove it.
    • Remove the right speaker,
Conclusione
Altre 3 persone hanno completato questa guida.
Aiden Baker
Membro da: 19/09/2015
11.323 Reputazione
22 Guide realizzate
Cooperators Membro di Cooperators
Community
14 Membri
78 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 36
Tutti i Tempi: 404
