Introduzione
This guide will show you how to replace the motherboard in a Lenovo Yoga 710-15ISK laptop. The motherboard is a circuit board that is responsible for connecting all of your hardware to your processor. If your laptop is getting the Blue Screen of Death or is freezing and glitching a lot, you may want to consider replacing your motherboard. When replacing your motherboard, be sure to save all of your current components to transfer to the new one—some hardware (such as the RAM or Wi-Fi chip) can be easy to miss, and if you accidentally get rid of them with your old motherboard, your laptop will have issues.
Cosa ti serve
Flip your laptop over so the bottom is facing upwards.
Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
Remove seven 2 mm screws from the motherboard using a Phillips #0 screwdriver.
