Salta al contenuto principale
Lenovo Yoga 710-15ISK Motherboard Replacement
Cosa ti serve
  1. Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: passo 1, immagine 1 di 2 Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
  2. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 2, immagine 1 di 1
    • Pry the back cover off of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: passo 3, immagine 1 di 2 Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the battery from the laptop.
  6. Lenovo Yoga 710-15ISK Motherboard Replacement, Fans: passo 6, immagine 1 di 1
    • Remove the four 1.5 mm screws from the fans with a Phillips #00 screwdriver.
  7. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 7, immagine 1 di 1
    • Unplug the wire connecting the fan to the motherboard by gently pulling the white head from the port.
  8. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 8, immagine 1 di 2 Lenovo Yoga 710-15ISK Motherboard Replacement: passo 8, immagine 2 di 2
    • Lift both fans to remove them from the laptop.
  9. Lenovo Yoga 710-15ISK Motherboard Replacement, SSD: passo 9, immagine 1 di 1
    • Remove the sticker from the SSD to gain access to the screw underneath.
  10. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 10, immagine 1 di 2 Lenovo Yoga 710-15ISK Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the screw holding the SSD in place using a Phillips #0 screwdriver.
    • Gently pull on the plastic clip next to the screw until the stick is freed and bounces up.
  11. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 11, immagine 1 di 1
    • Slide the SSD out of the laptop.
  12. Lenovo Yoga 710-15ISK Motherboard Replacement, Motherboard: passo 12, immagine 1 di 1
    • Remove seven 2 mm screws from the motherboard using a Phillips #0 screwdriver.
  13. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 13, immagine 1 di 3 Lenovo Yoga 710-15ISK Motherboard Replacement: passo 13, immagine 2 di 3 Lenovo Yoga 710-15ISK Motherboard Replacement: passo 13, immagine 3 di 3
    • Unplug four cables attached to the motherboard.
    • For the flat ribbon wires, lift the black tabs holding them in place before removing them.
  14. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 14, immagine 1 di 1
    • Carefully lift out the motherboard to remove it from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 286
