Salta al contenuto principale
Lenovo Yoga 710-15IKB Solid State Drive Replacement
Cosa ti serve
  1. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 2, immagine 1 di 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 3, immagine 1 di 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 4, immagine 1 di 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 6, immagine 1 di 1
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Solid State Drive: passo 7, immagine 1 di 1
    • Remove the one JIS 1 screw holding the solid state drive in place.
  8. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 8, immagine 1 di 1
    • Gently pull the solid state drive out and up to remove it from the connector.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
No need to remove battery. No need for tweezers.
Shane Whittet - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 53
Tutti i Tempi: 7,008
