Introduzione
Solid state drives are known to fail occasionally, but this doesn't mean you have to do away with your laptop entirely. Replacing a bad drive is as simple as removing the battery and a single screw. Failure can be caused by heat, voltage fluctuation, and age.
Cosa ti serve
Remove the one JIS 1 screw holding the solid state drive in place.
Altre 3 persone hanno completato questa guida.
