Salta al contenuto principale
Lenovo Yoga 710-14IKB RAM Replacement
Cosa ti serve
  1. Lenovo Yoga 710-14IKB RAM Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB RAM Replacement: passo 2, immagine 1 di 3 Lenovo Yoga 710-14IKB RAM Replacement: passo 2, immagine 2 di 3 Lenovo Yoga 710-14IKB RAM Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB RAM Replacement, RAM: passo 3, immagine 1 di 2 Lenovo Yoga 710-14IKB RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Use blue plastic opening tool to pry the ram cover loose. Carefully lift up the ram cover and remove it from the laptop.
  4. Lenovo Yoga 710-14IKB RAM Replacement: passo 4, immagine 1 di 2 Lenovo Yoga 710-14IKB RAM Replacement: passo 4, immagine 2 di 2
    • Locate the ram hold downs.
    • Push outwards on the hold downs to release the RAM.
  5. Lenovo Yoga 710-14IKB RAM Replacement: passo 5, immagine 1 di 2 Lenovo Yoga 710-14IKB RAM Replacement: passo 5, immagine 2 di 2
    • Remove the RAM by pulling away from the RAM socket.
Conclusione
Altre 14 persone hanno completato questa guida.
Grant Doerksen
Membro da: 04/17/17
1.005 Reputazione
5 Guide realizzate
Cal Poly, Team S14-G5, Banghart Spring 2017 Membro di Cal Poly, Team S14-G5, Banghart Spring 2017
CPSU-BANGHART-S17S14G5
4 Membri
27 Guide realizzate
4 Commenti
Hi, can the RAM be expandable and what is the highest RAM expansion this lenovo YOGA 710-14IKB can take?
victoria - Replica
Hi Victoria, I replaced the 8GB RAM stick with a single 16GB RAM stick and this does work!
Johannes de Wit -
una pregunta, cuantas ranuras de memoria RAM tiene?
One question, how many RAM slots does it have?
andres arce - Replica
It has 1 RAM slot
Lil Youman -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 44
Tutti i Tempi: 6,637
