Salta al contenuto principale
Lenovo Yoga 710-11ISK Motherboard Replacement
Cosa ti serve
  1. Lenovo Yoga 710-11ISK Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove the eleven screws that attach the back panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Motherboard Replacement: passo 2, immagine 1 di 1
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Motherboard Replacement: passo 3, immagine 1 di 2 Lenovo Yoga 710-11ISK Motherboard Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the four screws securing the battery.
    • Hold the cable connector on both sides and gently pull it directly out of its port.
    • Lift the battery up and out.
  4. Lenovo Yoga 710-11ISK Motherboard Replacement: passo 4, immagine 1 di 2 Lenovo Yoga 710-11ISK Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the eight screws securing the motherboard, Wi-Fi card, and SSD card.
    • Unplug the Wi-Fi and SSD cards from the motherboard along with the attached wire harnesses.
  5. Lenovo Yoga 710-11ISK Motherboard Replacement: passo 5, immagine 1 di 2 Lenovo Yoga 710-11ISK Motherboard Replacement: passo 5, immagine 2 di 2
    • Lift the motherboard up and out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 192
