Salta al contenuto principale
Lenovo Yoga 700-11ISK Touchpad Replacement
Cosa ti serve
  1. Lenovo Yoga 700-11ISK Touchpad Replacement, Back Panel: passo 1, immagine 1 di 2 Lenovo Yoga 700-11ISK Touchpad Replacement, Back Panel: passo 1, immagine 2 di 2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Touchpad Replacement: passo 2, immagine 1 di 1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Touchpad Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Touchpad Replacement: passo 4, immagine 1 di 1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: passo 5, immagine 1 di 3 Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: passo 5, immagine 2 di 3 Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: passo 5, immagine 3 di 3
    • Remove the four 4mm Phillips #1 screws holding the touchpad onto the laptop.
    • Use a spudger to lift up the two black tabs on the ZIF connectors and then pull the cable out by the blue tab.
    • The cable should slide in and out effortlessly. If there is resistance when pulling the cable, double check the black tabs.
  6. Lenovo Yoga 700-11ISK Touchpad Replacement: passo 6, immagine 1 di 1
    • Slightly separate the two halves of the laptop with one hand and slide the touchpad out from the laptop with the other.
    • There may be silver tape holding the touchpad to the laptop. You do not need to replace the tape when reassembling the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Sean Wong
Membro da: 10/06/16
859 Reputazione
3 Guide realizzate
Cal Poly, Team 15-6, Livingston Fall 2016 Membro di Cal Poly, Team 15-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G6
4 Membri
7 Guide realizzate
Un commento
The “Tools Required” section says “Torx T7” but Step 1 lists, and (more importantly) the actual device has Torx T5 screws.
Step 5 suggests using a spudger, so perhaps that should be listed too.
alan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,194
