Salta al contenuto principale
Lenovo Yoga 3 Pro Speakers Replacement
Cosa ti serve
  1. Lenovo Yoga 3 Pro Speakers Replacement, Battery: passo 1, immagine 1 di 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Speakers Replacement: passo 2, immagine 1 di 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Speakers Replacement: passo 3, immagine 1 di 1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Speakers Replacement: passo 4, immagine 1 di 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Speakers Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Speakers Replacement: passo 6, immagine 1 di 1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro Speakers Replacement, Speakers: passo 7, immagine 1 di 1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro Speakers Replacement: passo 8, immagine 1 di 2 Lenovo Yoga 3 Pro Speakers Replacement: passo 8, immagine 2 di 2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro Speakers Replacement: passo 9, immagine 1 di 3 Lenovo Yoga 3 Pro Speakers Replacement: passo 9, immagine 2 di 3 Lenovo Yoga 3 Pro Speakers Replacement: passo 9, immagine 3 di 3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro Speakers Replacement: passo 10, immagine 1 di 2 Lenovo Yoga 3 Pro Speakers Replacement: passo 10, immagine 2 di 2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro Speakers Replacement: passo 11, immagine 1 di 2 Lenovo Yoga 3 Pro Speakers Replacement: passo 11, immagine 2 di 2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 12-17, Maness Fall 2015 Membro di Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,798
