Salta al contenuto principale
Lenovo Yoga 3 11 Motherboard Replacement
Cosa ti serve
  1. Lenovo Yoga 3 11 Motherboard Replacement, Lower Case: passo 1, immagine 1 di 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Motherboard Replacement, Battery: passo 2, immagine 1 di 3 Lenovo Yoga 3 11 Motherboard Replacement, Battery: passo 2, immagine 2 di 3 Lenovo Yoga 3 11 Motherboard Replacement, Battery: passo 2, immagine 3 di 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Motherboard Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Motherboard Replacement: passo 4, immagine 1 di 2 Lenovo Yoga 3 11 Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Motherboard Replacement: passo 5, immagine 1 di 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 1
    Compra
    • Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
  7. Lenovo Yoga 3 11 Motherboard Replacement: passo 7, immagine 1 di 1
    • Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
  8. Lenovo Yoga 3 11 Motherboard Replacement: passo 8, immagine 1 di 1
    • Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
  9. Lenovo Yoga 3 11 Motherboard Replacement: passo 9, immagine 1 di 1
    • Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
  10. Lenovo Yoga 3 11 Motherboard Replacement: passo 10, immagine 1 di 1
    • Use a plastic opening tool to gently pry up the screen cable from the motherboard.
  11. Lenovo Yoga 3 11 Motherboard Replacement: passo 11, immagine 1 di 3 Lenovo Yoga 3 11 Motherboard Replacement: passo 11, immagine 2 di 3 Lenovo Yoga 3 11 Motherboard Replacement: passo 11, immagine 3 di 3
    • Use a pair of tweezers to disconnect the "I/O Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Use a pair of tweezers to disconnect the "MB Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Remove the ribbon cable from the device.
  12. Lenovo Yoga 3 11 Motherboard Replacement: passo 12, immagine 1 di 3 Lenovo Yoga 3 11 Motherboard Replacement: passo 12, immagine 2 di 3 Lenovo Yoga 3 11 Motherboard Replacement: passo 12, immagine 3 di 3
    • Remove the two 2 mm Phillips #00 screws securing the wireless card (top) and the SSD (bottom).
    • Use a pair of tweezers to disconnect the black and white antenna cables that are connected to the wireless card.
    • Gently lift the wireless card and SSD up and out of the device.
  13. Lenovo Yoga 3 11 Motherboard Replacement: passo 13, immagine 1 di 1
    • Remove the three black 2 mm Phillips #00 screws.
    • Remove the single silver 4 mm Phillips #00 screw.
  14. Lenovo Yoga 3 11 Motherboard Replacement: passo 14, immagine 1 di 1
    • Gently lift the motherboard up and out of the device.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 2-3, Blackwell Fall 2015 Membro di USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Membri
11 Guide realizzate
Un commento
Not as difficult as I thought. I was surprised that there were no empty RAM locations. Usually on a Notebookk lliek this, there is one RAM location soldered to MB, and one empty slot for upgrade. I worked on an identical Yoga 3 pro that ran 16GB. But aht meant it was soldered at factory to one 16GB RAM setup.
Mick Thielen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 20
Tutti i Tempi: 7,377
