Introduzione
If your battery does not hold as much charge as it used to and you need to replace it, then you have come to the right place! This guide will show you how to successfully remove and replace the battery.
Cosa ti serve
Remove the eleven 6 mm T5 Torx screws securing the lower case.
Gently lift the lower case up and away from the device.
