Salta al contenuto principale
Lenovo Yoga 2 Pro Wireless Card Replacement
Cosa ti serve
  1. Lenovo Yoga 2 Pro Wireless Card Replacement, Wireless Card: passo 1, immagine 1 di 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a T5 Torx screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Wireless Card Replacement: passo 2, immagine 1 di 1
    • Gently lift off the back cover.
  3. Lenovo Yoga 2 Pro Wireless Card Replacement: passo 3, immagine 1 di 1
    • Locate the wireless module above the battery in the top left corner of the computer.
    • Using a spudger, disconnect the two metal connectors by popping the metal piece up from the wireless module.
  4. Lenovo Yoga 2 Pro Wireless Card Replacement: passo 4, immagine 1 di 1
    • Remove the one 1/16” screw using a Phillips #00 screwdriver.
  5. Lenovo Yoga 2 Pro Wireless Card Replacement: passo 5, immagine 1 di 2 Lenovo Yoga 2 Pro Wireless Card Replacement: passo 5, immagine 2 di 2
    • Slide the wireless module towards the battery and lift out of the laptop.
Conclusione
Altre 9 persone hanno completato questa guida.
Thomas Simko
Membro da: 10/01/15
2.516 Reputazione
5 Guide realizzate
Cal Poly, Team 12-14, Maness Fall 2015 Membro di Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Membri
12 Guide realizzate
2 Commenti
Great info on this
Frank Kristoffersen - Replica
Be careful, there is a very restrictive Whitelist in the BIOS for potential replacements, unofficial support available via their forums;
(tl;dr - go with Intel AC 7260 - m.2 connection)
https://forums.lenovo.com/t5/Lenovo-Yoga...
Jamie Haustead - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 41
Tutti i Tempi: 11,264
