Salta al contenuto principale
Lenovo Yoga 2 Pro Trackpad Replacement
Cosa ti serve
  1. Lenovo Yoga 2 Pro Trackpad Replacement, Battery: passo 1, immagine 1 di 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Trackpad Replacement: passo 2, immagine 1 di 1
    • Gently unclip and lift off the back cover.
  3. Lenovo Yoga 2 Pro Trackpad Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
  4. Lenovo Yoga 2 Pro Trackpad Replacement: passo 4, immagine 1 di 1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  5. Lenovo Yoga 2 Pro Trackpad Replacement: passo 5, immagine 1 di 2 Lenovo Yoga 2 Pro Trackpad Replacement: passo 5, immagine 2 di 2
    • Remove the battery from the computer.
  6. Lenovo Yoga 2 Pro Trackpad Replacement, Trackpad: passo 6, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the eight 1/8" screws surrounding the trackpad.
  7. Lenovo Yoga 2 Pro Trackpad Replacement: passo 7, immagine 1 di 1
    • Using a sharp tool such as tweezers, lift up the black cover that is on top of the ribbon cable.
  8. Lenovo Yoga 2 Pro Trackpad Replacement: passo 8, immagine 1 di 1
    • With tweezers, gently slide the ribbon cable out from under the connector.
  9. Lenovo Yoga 2 Pro Trackpad Replacement: passo 9, immagine 1 di 2 Lenovo Yoga 2 Pro Trackpad Replacement: passo 9, immagine 2 di 2
    • Lift the trackpad out of the computer.
Conclusione
Altre 6 persone hanno completato questa guida.
Thomas Simko
Membro da: 10/01/15
2.511 Reputazione
5 Guide realizzate
Cal Poly, Team 12-14, Maness Fall 2015 Membro di Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Membri
12 Guide realizzate
3 Commenti
Where can I buy this trackpad? Mine is done.
Jorge Suarez - Replica
Same here. Where can I buy the part? I cannot even find a part number.
iwaniec - Replica
I got a lot of different options on ebay but cannot rely on them. I think we could order it from IBM FRU parts but only by email or phone at:
https://www-304.ibm.com/shop/americas/co...
FRU: 73040855
Will try tomorrow
LUIS GARZA - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 9,392
