Salta al contenuto principale
Lenovo Yoga 2 13" Screen Replacement
Cosa ti serve
  1. Lenovo Yoga 2 13" Screen Replacement, Screen: passo 1, immagine 1 di 2 Lenovo Yoga 2 13" Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
    • Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
  2. Lenovo Yoga 2 13" Screen Replacement: passo 2, immagine 1 di 1
    • Using the Jimmy, remove the long centerpiece covering between the hinges.
  3. Lenovo Yoga 2 13" Screen Replacement: passo 3, immagine 1 di 1
    • Detach the screen from the front panel by sliding the screen up about 2mm. Do not pull too far, as there are still connected wires.
  4. Lenovo Yoga 2 13" Screen Replacement: passo 4, immagine 1 di 1
    • Locate the gold wire and follow it to two clips. Remove the clips and the clear tape securing the wire.
    • Gently unsnap the wire from the hooks along the perimeter, and remove any tape along the wire.
  5. Lenovo Yoga 2 13" Screen Replacement: passo 5, immagine 1 di 2 Lenovo Yoga 2 13" Screen Replacement: passo 5, immagine 2 di 2
    • Completely separate the screen from the laptop.
    • During reassembly, remember to set the screen about 2 mm beyond the lid top edge. Then, slide down to engage the hinges.
Conclusione
Altre 11 persone hanno completato questa guida.
Nichelle
Membro da: 03/11/15
1.550 Reputazione
5 Guide realizzate
Marist, Team 1-2, Laflen Spring 2015 Membro di Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 Membri
7 Guide realizzate
3 Commenti
Hi Nichelle,
thanks for your guide. Step 1 and 2 - no problem. But how actually did you do step 3? I can't detach the screen, I can just lift it a few millimeters at the corners or at the side, totally hard..
edit: Ok got it: slide the touch-lcd up a bit :)
Simon - Replica
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
Emmanuel Duarte - Replica
I used laptopscreen.com.
ken - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 15,972
