Salta al contenuto principale
Lenovo Yoga 2 13" Keyboard Keys Replacement
Cosa ti serve
  1. Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: passo 1, immagine 1 di 2 Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: passo 1, immagine 2 di 2
    • Using a flat tool, carefully jimmy the selected key until it pops out.
  2. Lenovo Yoga 2 13" Keyboard Keys Replacement: passo 2, immagine 1 di 1
    • To insert a new key, simply place and apply pressure until it snaps into place.
Conclusione
Nichelle
Membro da: 03/11/15
1.568 Reputazione
5 Guide realizzate
Marist, Team 1-2, Laflen Spring 2015 Membro di Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 Membri
7 Guide realizzate
4Commenti sulla guida
this doesn't fix a non-working electric contact, does it?
Simon - Replica Condividi
I came across this page since my Yoga 2 Pro had 2 keys that didn't press down very well. Instead of fully removing the keys, I used a flat tool to pry up the key a little bit, then used compressed air to clean out under the keys. I had to do this a few times from a few different angels, but it finally worked
and the keys feel like normal again.
a.adler55 - Replica Condividi
Does this break the old keys so that you must replace them or is it possible to insert the same ones again?
Johannes Scheller - Replica Condividi
For those who found this page in 2022, I’ll answer the old questions so you don’t have to look elsewhere.
This does not fix a non-working electrical contact, this is just for replacing the top.
Secondly no it does not break the old key if you do it carefully.
Kind Regards
Lost Yogi
Lost Yogi - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 82
Tutti i Tempi: 18,440
