Salta al contenuto principale
Lenovo Yoga 2 11" Battery Replacement
Cosa ti serve
  1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Battery Replacement: passo 2, immagine 1 di 1
    • Carefully separate back panel from laptop.
  3. Lenovo Yoga 2 11" Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
  4. Lenovo Yoga 2 11" Battery Replacement: passo 4, immagine 1 di 1
    • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
  5. Lenovo Yoga 2 11" Battery Replacement: passo 5, immagine 1 di 2 Lenovo Yoga 2 11" Battery Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
  6. Lenovo Yoga 2 11" Battery Replacement: passo 6, immagine 1 di 1
    • Once all of the wires are detached, carefully remove the battery and replace.
Conclusione
Altre 12 persone hanno completato questa guida.
Cal Poly, Team 4-3, Maness Fall 2015 Membro di Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Membri
5 Guide realizzate
4 Commenti
how do I remove unathorized battery error?
Manuel Durugas - Replica
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - Replica
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - Replica
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 43
Tutti i Tempi: 26,691
