Salta al contenuto principale
Lenovo Yoga 2 11" Back Panel Replacement
Cosa ti serve
  1. Lenovo Yoga 2 11" Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Back Panel Replacement: passo 2, immagine 1 di 1
    • Carefully separate back panel from laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Peyton Leeson
Membro da: 10/01/15
939 Reputazione
4 Guide realizzate
Cal Poly, Team 4-3, Maness Fall 2015 Membro di Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Membri
5 Guide realizzate
3 Commenti
Thanks for this manual.
Would you have the chance to add a photo of the machine without the cover on? My idea is to be able to see what is easily accessible in order to answer some other users' questions such as this one: Could I replace the hard drive with an SSD
dauffret - Replica
I believe the "hex screwdriver" is not the correct tool required...I believe it's the Torx screwdriver that would be the correct tool.
David Briggman - Replica
Not sure if the description has been updated since the 07/30/17 comment but the required tool is a T5 Torx screwdriver that is mentioned in the ‘Tools’ section…and they are not very common!
Ken Swanston - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,736
