Salta al contenuto principale
Lenovo Yoga 11e Chromebook Battery Replacement
Cosa ti serve
  1. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the back panel: passo 1, immagine 1 di 1
    • There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • NOTE: You may void your warranty completing this replacement
  2. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery screws: passo 2, immagine 1 di 1
    • There will be 2 other Philips screws under the cover there should also be two arrows pointing at each screw that needs to be removed.
  3. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery: passo 3, immagine 1 di 2 Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery: passo 3, immagine 2 di 2
    • Pull up the battery slightly by the tab and pull back
    • Remove the connector from the motherboard and pull the battery up and away from the board
    • Make sure not to pull all the way back as the battery is still connected to the motherboard
    • The computer may not boot when you try to turn it on, plug it into its power supply and it should boot.
Conclusione
Congratulations! You hopefully have successfully completed this guide! To reassemble your device follow the steps backwards.
Altre 4 persone hanno completato questa guida.
Corey Meyer
Membro da: 05/01/17
2.292 Reputazione
2 Guide realizzate
Kid fixers Membro di Kid fixers
Community
172 Membri
229 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 3,143
