Salta al contenuto principale
Lenovo YOGA 730-15IKB Right Fan Replacement
Cosa ti serve
  1. Lenovo YOGA 730-15IKB Right Fan Replacement, Bottom Cover: passo 1, immagine 1 di 2 Lenovo YOGA 730-15IKB Right Fan Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Right Fan Replacement: passo 2, immagine 1 di 2 Lenovo YOGA 730-15IKB Right Fan Replacement: passo 2, immagine 2 di 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Right Fan Replacement: passo 3, immagine 1 di 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Right Fan Replacement, Right Fan: passo 4, immagine 1 di 1
    • When the laptop is upside down, the right fan is on the left side of the laptop near the large metal RAM cover.
    • Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
    • You can also use the white tabs on the connector to push the cable free.
  5. Lenovo YOGA 730-15IKB Right Fan Replacement: passo 5, immagine 1 di 2 Lenovo YOGA 730-15IKB Right Fan Replacement: passo 5, immagine 2 di 2
    • Remove two 4mm Phillips #1 screws.
  6. Lenovo YOGA 730-15IKB Right Fan Replacement: passo 6, immagine 1 di 1
    • Pull the fan up and towards the front of the laptop.
Conclusione
Cal Poly, Team S1-G6, White Winter 2020 Membro di Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 Membri
27 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 35
Tutti i Tempi: 2,799
