Salta al contenuto principale
Lenovo Y70-70 Touch Fan Replacement
Cosa ti serve
  1. Lenovo Y70-70 Touch Fan Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Y70-70 Touch Fan Replacement: passo 2, immagine 1 di 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Y70-70 Touch Fan Replacement, Fan: passo 3, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
  4. Lenovo Y70-70 Touch Fan Replacement: passo 4, immagine 1 di 1
    • Using a pair of blunt tweezers, disconnect the fan from the motherboard.
    • Remove the fan from the device.
Conclusione
Un commento
What kind of fan is that?
I need to know what to order for replacement.
vlastimil.beno - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 358
