Salta al contenuto principale
Lenovo Y520-15IKBN Display Replacement
Cosa ti serve
  1. Lenovo Y520-15IKBN Display Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  2. Lenovo Y520-15IKBN Display Replacement: passo 2, immagine 1 di 2 Lenovo Y520-15IKBN Display Replacement: passo 2, immagine 2 di 2
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  3. Lenovo Y520-15IKBN Display Replacement: passo 3, immagine 1 di 1
    • Lift the battery up and out of the chassis.
  4. Lenovo Y520-15IKBN Display Replacement, Display: passo 4, immagine 1 di 1
    • Use an opening tool to pry off the display bezel.
  5. Lenovo Y520-15IKBN Display Replacement: passo 5, immagine 1 di 1
    • Remove the four 4 mm screws with a Phillips #1 screwdriver.
  6. Lenovo Y520-15IKBN Display Replacement: passo 6, immagine 1 di 1
    • Flip up the gate on the display ribbon cable, and pull it directly out of its port.
    • Remove the display from the computer.
Conclusione
Comm 260 Team 15 Membro di Comm 260 Team 15
Community
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 40
Tutti i Tempi: 1,229
