Salta al contenuto principale
Lenovo Y50-70 Touch Trackpad Replacement
Cosa ti serve
  1. Lenovo Y50-70 Touch Trackpad Replacement, Trackpad: passo 1, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement, Trackpad: passo 1, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement, Trackpad: passo 1, immagine 3 di 3
    • Use a Phillips #1 screwdriver to unscrew and remove the ten 6 mm screws on the back of the laptop.
    • Grab and pull off the back.
  2. Lenovo Y50-70 Touch Trackpad Replacement: passo 2, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 2, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the battery.
    • Grab the battery cable and gently pull it free from the cable connector.
    • Remove the battery from the laptop.
  3. Lenovo Y50-70 Touch Trackpad Replacement: passo 3, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 3, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the hard drive.
    • Grab the marked cable attached to the hard drive, and gently pull to unplug.
    • Remove the hard drive from the laptop.
  4. Lenovo Y50-70 Touch Trackpad Replacement: passo 4, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 4, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 4, immagine 3 di 3
    • Grab marked cables and pull them out from their plug-in.
  5. Lenovo Y50-70 Touch Trackpad Replacement: passo 5, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 5, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 5, immagine 3 di 3
    • Grab the top set of marked cables and pull up to remove them.
    • Grab the lower marked cable and pull it out from the plug.
  6. Lenovo Y50-70 Touch Trackpad Replacement: passo 6, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 6, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 6, immagine 3 di 3
    • Grab marked cables and pull up to unplug.
  7. Lenovo Y50-70 Touch Trackpad Replacement: passo 7, immagine 1 di 2 Lenovo Y50-70 Touch Trackpad Replacement: passo 7, immagine 2 di 2
    • Grab the marked cable and pull out to unplug.
  8. Lenovo Y50-70 Touch Trackpad Replacement: passo 8, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 8, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 8, immagine 3 di 3
    • Grab the black tab on top of the cable and pull up to unplug.
  9. Lenovo Y50-70 Touch Trackpad Replacement: passo 9, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 9, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 9, immagine 3 di 3
    • Lift the black tab on top of the marked cable.
    • Grab the colored tab on the cable and pull to remove the cable.
  10. Lenovo Y50-70 Touch Trackpad Replacement: passo 10, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 10, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 10, immagine 3 di 3
  11. Lenovo Y50-70 Touch Trackpad Replacement: passo 11, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 11, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 11, immagine 3 di 3
  12. Lenovo Y50-70 Touch Trackpad Replacement: passo 12, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 12, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 12, immagine 3 di 3
    • Lift the black tab on top of the marked cables.
    • Grab the colored tab on the cables and pull to remove the cables.
  13. Lenovo Y50-70 Touch Trackpad Replacement: passo 13, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 13, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 13, immagine 3 di 3
    • Carefully remove the yellow tape on top of the cable.
  14. Lenovo Y50-70 Touch Trackpad Replacement: passo 14, immagine 1 di 2 Lenovo Y50-70 Touch Trackpad Replacement: passo 14, immagine 2 di 2
    • Use a Phillips #1 screwdriver to unscrew and remove the six 7 mm screws from the heat sink.
    • Grab and lift the heatsink off the motherboard.
  15. Lenovo Y50-70 Touch Trackpad Replacement: passo 15, immagine 1 di 2 Lenovo Y50-70 Touch Trackpad Replacement: passo 15, immagine 2 di 2
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws marked with red circles on the motherboard.
    • Grab and lift the motherboard up and out from the laptop.
  16. Lenovo Y50-70 Touch Trackpad Replacement: passo 16, immagine 1 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 16, immagine 2 di 3 Lenovo Y50-70 Touch Trackpad Replacement: passo 16, immagine 3 di 3
    • Use a Phillips #1 screwdriver to unscrew and remove the two 6 mm screws at the top of the trackpad.
    • Push on the marked clips at the top of the trackpad.
    • Then, when undone from clips, lift the trackpad out from the laptop.
Conclusione
Ryan McCann
Membro da: 04/12/22
305 Reputazione
1 Guida realizzata
IUPUI, Team 6-6, Beck Spring 2022 Membro di IUPUI, Team 6-6, Beck Spring 2022
IUPUI-BECK-S22S6G6
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 611
