Salta al contenuto principale
Lenovo Y50-70 Touch Motherboard Replacement
Cosa ti serve
  1. Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Use a Phillips #1 screwdriver to unscrew and remove the ten 6 mm screws on the back of the laptop.
    • Grab and pull off the back.
  2. Lenovo Y50-70 Touch Motherboard Replacement: passo 2, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 2, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the battery.
    • Grab the battery cable and gently pull it free from the cable connector.
    • Remove the battery.
  3. Lenovo Y50-70 Touch Motherboard Replacement: passo 3, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 3, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the hard drive.
    • Grab the marked cable attached to the hard drive, and gently pull to unplug.
    • Remove the hard drive from the laptop.
  4. Lenovo Y50-70 Touch Motherboard Replacement: passo 4, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 4, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 4, immagine 3 di 3
    • Grab marked cables and pull them out from their plug-in.
  5. Lenovo Y50-70 Touch Motherboard Replacement: passo 5, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 5, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 5, immagine 3 di 3
    • Grab the top set of marked cables and pull up to remove them.
    • Grab the lower marked cable and pull it out from their plug.
  6. Lenovo Y50-70 Touch Motherboard Replacement: passo 6, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 6, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 6, immagine 3 di 3
    • Grab marked cables and pull up to unplug.
  7. Lenovo Y50-70 Touch Motherboard Replacement: passo 7, immagine 1 di 2 Lenovo Y50-70 Touch Motherboard Replacement: passo 7, immagine 2 di 2
    • Grab marked cables and pull out to unplug.
  8. Lenovo Y50-70 Touch Motherboard Replacement: passo 8, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 8, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 8, immagine 3 di 3
    • Grab the black tab on top of the cable and pull up to unplug.
  9. Lenovo Y50-70 Touch Motherboard Replacement: passo 9, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 9, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 9, immagine 3 di 3
    • Lift the black tab on top of the marked cable.
    • Grab the colored tab on the cable and pull to remove the cable.
  10. Lenovo Y50-70 Touch Motherboard Replacement: passo 10, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 10, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 10, immagine 3 di 3
  11. Lenovo Y50-70 Touch Motherboard Replacement: passo 11, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 11, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 11, immagine 3 di 3
  12. Lenovo Y50-70 Touch Motherboard Replacement: passo 12, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 12, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 12, immagine 3 di 3
    • Lift the black tab on top of the marked cables.
    • Grab the colored tab on the cables and pull to remove the cables.
  13. Lenovo Y50-70 Touch Motherboard Replacement: passo 13, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 13, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 13, immagine 3 di 3
    • Use a Phillips #1 screwdriver to unscrew and remove the six 7 mm screws from the heat sink.
    • Grab and lift the heatsink off the motherboard.
  14. Lenovo Y50-70 Touch Motherboard Replacement: passo 14, immagine 1 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 14, immagine 2 di 3 Lenovo Y50-70 Touch Motherboard Replacement: passo 14, immagine 3 di 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws marked with red circles on the motherboard.
    • Grab and lift the motherboard up and out from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team 6-6, Beck Spring 2022 Membro di IUPUI, Team 6-6, Beck Spring 2022
IUPUI-BECK-S22S6G6
4 Membri
3 Guide realizzate
Un commento
Attempting this tomorrow soldiers, wish me luck o7
j.c.glaab - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,127
