Salta al contenuto principale
Lenovo Y50 Touch Speakers Replacement
Cosa ti serve
  1. Lenovo Y50 Touch Speakers Replacement, Back: passo 1, immagine 1 di 2 Lenovo Y50 Touch Speakers Replacement, Back: passo 1, immagine 2 di 2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50 Touch Speakers Replacement: passo 2, immagine 1 di 2 Lenovo Y50 Touch Speakers Replacement: passo 2, immagine 2 di 2
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50 Touch Speakers Replacement, Fan: passo 3, immagine 1 di 2 Lenovo Y50 Touch Speakers Replacement, Fan: passo 3, immagine 2 di 2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50 Touch Speakers Replacement: passo 4, immagine 1 di 3 Lenovo Y50 Touch Speakers Replacement: passo 4, immagine 2 di 3 Lenovo Y50 Touch Speakers Replacement: passo 4, immagine 3 di 3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50 Touch Speakers Replacement: passo 5, immagine 1 di 3 Lenovo Y50 Touch Speakers Replacement: passo 5, immagine 2 di 3 Lenovo Y50 Touch Speakers Replacement: passo 5, immagine 3 di 3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50 Touch Speakers Replacement: passo 6, immagine 1 di 3 Lenovo Y50 Touch Speakers Replacement: passo 6, immagine 2 di 3 Lenovo Y50 Touch Speakers Replacement: passo 6, immagine 3 di 3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50 Touch Speakers Replacement: passo 7, immagine 1 di 2 Lenovo Y50 Touch Speakers Replacement: passo 7, immagine 2 di 2
    • Lift the fan off of the laptop.
  8. Lenovo Y50 Touch Speakers Replacement, Speakers: passo 8, immagine 1 di 1
    • Locate the three speakers within the laptop.
    • The bass speaker is located near the fan's original position.
    • The side speakers are located at the upper left and right corners of the laptop.
  9. Lenovo Y50 Touch Speakers Replacement: passo 9, immagine 1 di 3 Lenovo Y50 Touch Speakers Replacement: passo 9, immagine 2 di 3 Lenovo Y50 Touch Speakers Replacement: passo 9, immagine 3 di 3
    • Using a Philips #1 screwdriver, remove the two 2.5 mm screws securing the bass speaker.
  10. Lenovo Y50 Touch Speakers Replacement: passo 10, immagine 1 di 2 Lenovo Y50 Touch Speakers Replacement: passo 10, immagine 2 di 2
    • Unplug the bass speaker from the motherboard.
  11. Lenovo Y50 Touch Speakers Replacement: passo 11, immagine 1 di 3 Lenovo Y50 Touch Speakers Replacement: passo 11, immagine 2 di 3 Lenovo Y50 Touch Speakers Replacement: passo 11, immagine 3 di 3
    • Remove the bass speaker from the laptop.
  12. Lenovo Y50 Touch Speakers Replacement: passo 12, immagine 1 di 3 Lenovo Y50 Touch Speakers Replacement: passo 12, immagine 2 di 3 Lenovo Y50 Touch Speakers Replacement: passo 12, immagine 3 di 3
    • Using a Philips #1 screwdriver, Remove the 2.5 mm screw holding each side speaker to the laptop.
  13. Lenovo Y50 Touch Speakers Replacement: passo 13, immagine 1 di 2 Lenovo Y50 Touch Speakers Replacement: passo 13, immagine 2 di 2
    • Unplug the side speakers from the motherboard.
  14. Lenovo Y50 Touch Speakers Replacement: passo 14, immagine 1 di 3 Lenovo Y50 Touch Speakers Replacement: passo 14, immagine 2 di 3 Lenovo Y50 Touch Speakers Replacement: passo 14, immagine 3 di 3
    • Remove the side speakers from the laptop.
    • The red and black wires connect to the right speaker, and the blue and white wires connect to to the left speaker.
    • The side speakers are independent from the bass speaker. It is possible to remove them without having to remove the bass speaker.
Conclusione
Altre 5 persone hanno completato questa guida.
Andrew Tran
Membro da: 01/21/15
820 Reputazione
2 Guide realizzate
Cal Poly, Team 18-1, Maness Winter 2015 Membro di Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 18
Tutti i Tempi: 3,503
