Salta al contenuto principale
Lenovo Y50 Touch RAM Replacement
Cosa ti serve
  1. Lenovo Y50 Touch RAM Replacement, RAM: passo 1, immagine 1 di 2 Lenovo Y50 Touch RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Place laptop on a flat surface with the back cover facing up.
    • Remove all twelve 6 mm long screws on the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
  2. Lenovo Y50 Touch RAM Replacement: passo 2, immagine 1 di 2 Lenovo Y50 Touch RAM Replacement: passo 2, immagine 2 di 2
    • Gently pull off the back cover of the laptop. It should come off easily.
  3. Lenovo Y50 Touch RAM Replacement, Locate the RAM: passo 3, immagine 1 di 1
    • The RAM should be located at the indicated area inside the laptop.
  4. Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: passo 4, immagine 1 di 2 Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: passo 4, immagine 2 di 2
    • Release the clamps securing the RAM by pushing each clamp away from the RAM.
    • Once the clamps are released, the RAM should be facing outward at an angle.
  5. Lenovo Y50 Touch RAM Replacement, Remove the RAM: passo 5, immagine 1 di 3 Lenovo Y50 Touch RAM Replacement, Remove the RAM: passo 5, immagine 2 di 3 Lenovo Y50 Touch RAM Replacement, Remove the RAM: passo 5, immagine 3 di 3
    • Gently unplug the RAM from its port.
    • Do not bend or drop the RAM, as this can affect its function.
    • You can replace up to two RAM sticks for this laptop. Just repeat step 4 for the second RAM port.
    • Pay attention to the arrangement of the pins on the RAM. When replacing the RAM, make sure the pins line up with the pins on the RAM port.
Conclusione
Altre 9 persone hanno completato questa guida.
Andrew Tran
Membro da: 01/21/15
820 Reputazione
2 Guide realizzate
Cal Poly, Team 18-1, Maness Winter 2015 Membro di Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Membri
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 5,502
