Salta al contenuto principale
Lenovo Y410P Speakers Replacement
Cosa ti serve
  1. Lenovo Y410P Speakers Replacement, Removal of Bottom Panel: passo 1, immagine 1 di 2 Lenovo Y410P Speakers Replacement, Removal of Bottom Panel: passo 1, immagine 2 di 2
    • Remove eight M2.5 x 8mm Phillips head screws, using a Phillips #0 screwdriver, in the specified locations.
    • Lift the bottom cover off and set it aside.
  2. Lenovo Y410P Speakers Replacement, Removal of Hard Drive: passo 2, immagine 1 di 2 Lenovo Y410P Speakers Replacement, Removal of Hard Drive: passo 2, immagine 2 di 2
    • Remove the two M2.5x4mm screws using a Phillips #0 screwdriver.
    • Slide the hard drive out of the casing.
    • Be careful when handling the hard drive; rough impacts may cause data loss.
  3. Lenovo Y410P Speakers Replacement, Remove Optical Drive: passo 3, immagine 1 di 3 Lenovo Y410P Speakers Replacement, Remove Optical Drive: passo 3, immagine 2 di 3 Lenovo Y410P Speakers Replacement, Remove Optical Drive: passo 3, immagine 3 di 3
    • With the laptop's bottom facing up, pull the optical drive release lever back and pull the optical drive out.
    • Unscrew the three M2x3mm Phillips head screws shown.
    • At the front edge of the laptop, empty the SD card holder by pressing on the card. This will allow for further disassembly in later steps.
  4. Lenovo Y410P Speakers Replacement, Remove Keyboard and Cables: passo 4, immagine 1 di 2 Lenovo Y410P Speakers Replacement, Remove Keyboard and Cables: passo 4, immagine 2 di 2
    • Remove the two M2.5 x 6mm screws using a Phillips #00 screwdriver.
    • Disconnect the two WiFi antenna cables.
    • Disconnect the sound connector.
  5. Lenovo Y410P Speakers Replacement: passo 5, immagine 1 di 1
    • Open the laptop hinge. Tip the laptop onto its side, and use the back end of the screwdriver to push the keyboard out from the optical drive area.
    • Turn the laptop right side up and pry the keyboard up slowly, until it is clear of the case.
    • Be careful of the ribbon cable when removing the keyboard. The ribbon is still attached.
    • Detach the ribbon cables by opening the specified latches.
  6. Lenovo Y410P Speakers Replacement, Removal of Palm Rest: passo 6, immagine 1 di 3 Lenovo Y410P Speakers Replacement, Removal of Palm Rest: passo 6, immagine 2 di 3 Lenovo Y410P Speakers Replacement, Removal of Palm Rest: passo 6, immagine 3 di 3
    • Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Turn the laptop on its side and pry the bottom from the top.
    • Only partially remove the palm rest; there is still a ribbon cable attached underneath it.
    • Remove the ribbon cable by opening its respective latch.
  7. Lenovo Y410P Speakers Replacement, Removal of Motherboard: passo 7, immagine 1 di 3 Lenovo Y410P Speakers Replacement, Removal of Motherboard: passo 7, immagine 2 di 3 Lenovo Y410P Speakers Replacement, Removal of Motherboard: passo 7, immagine 3 di 3
    • Remove the specified cable on top of the motherboard.
    • Flip the laptop over, and remove the specified cables.
    • Remove the two M2.5x4mm screws with a Phillips #0 screwdriver
    • Remove the motherboard with hands.
  8. Lenovo Y410P Speakers Replacement, Removal of Left Speaker: passo 8, immagine 1 di 2 Lenovo Y410P Speakers Replacement, Removal of Left Speaker: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Compra
    • Remove two M2.0 x 3mm flathead screws on the left side (using the small flathead screwdriver).
  9. Lenovo Y410P Speakers Replacement, Removal of Right Speaker: passo 9, immagine 1 di 2 Lenovo Y410P Speakers Replacement, Removal of Right Speaker: passo 9, immagine 2 di 2
    • Remove two M2.0 x 3mm flathead screws on the right side (using the small flathead screwdriver).
Conclusione
Altre 4 persone hanno completato questa guida.
Eric Chen
Membro da: 01/22/15
868 Reputazione
4 Guide realizzate
Cal Poly, Team 21-21, Maness Winter 2015 Membro di Cal Poly, Team 21-21, Maness Winter 2015
CPSU-MANESS-W15S21G21
4 Membri
6 Guide realizzate
2 Commenti
Hello Sir,
May I look how the speaker for y410p looks like and what is the model for the speaker? Where can I find that parts? Thanks.
Aiman Nazri - Replica
Where can i find the speaker parts?
beslielim96 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,255
