Salta al contenuto principale
Lenovo Y410P Hard Drive/SSD Replacement
Cosa ti serve
  1. Lenovo Y410P Hard Drive/SSD Replacement, Removal of Bottom Panel: passo 1, immagine 1 di 2 Lenovo Y410P Hard Drive/SSD Replacement, Removal of Bottom Panel: passo 1, immagine 2 di 2
    • Remove the eight M2.5x8mm Phillips head screws that fasten the bottom cover.
    • For the Lenovo Y510P, there's another screw in the center that has to be removed.
    • Lift bottom cover off and set aside.
    • On the Lenovo Y510P, use a black spudger around the outside edge to pop loose the bottom panel.
  2. Lenovo Y410P Hard Drive/SSD Replacement, Removal of Hard Drive: passo 2, immagine 1 di 2 Lenovo Y410P Hard Drive/SSD Replacement, Removal of Hard Drive: passo 2, immagine 2 di 2
    • If you intend to reuse this Hard Drive/SSD, be careful with the removal. Hard impact may result in damage.
    • First remove the two screws at the end of the Hard Drive bracket then slide the Hard Drive/SSD out of its seat.
Conclusione
Altre 7 persone hanno completato questa guida.
Brandon
Membro da: 01/22/15
527 Reputazione
2 Guide realizzate
Cal Poly, Team 21-21, Maness Winter 2015 Membro di Cal Poly, Team 21-21, Maness Winter 2015
CPSU-MANESS-W15S21G21
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 8,531
