Salta al contenuto principale
Lenovo X200 Memory Replacement
Cosa ti serve
  1. Lenovo X200 Memory Replacement, Memory: passo 1, immagine 1 di 1
    • 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
  2. Lenovo X200 Memory Replacement: passo 2, immagine 1 di 1
    • 2. Remove the panel to access the memory modules.
  3. Lenovo X200 Memory Replacement: passo 3, immagine 1 di 1
    • Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
    • Remove DIMM by gently spreading the socket connectors up and down as shown in the direction of the arrows and pull the DIMM out.
    • Insert the notched end of the DIMM into the socket.
    • Press the DIMM firmly, and pivot it until it snaps into the place.
    • Make sure that it is firmly fixed in the slot and does not move easily.
Conclusione
Altre 4 persone hanno completato questa guida.
James Finch
Membro da: 10/14/17
2.268 Reputazione
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,141
