Salta al contenuto principale
Lenovo Vibe Z2 Pro Charging Assembly Replacement
Cosa ti serve
  1. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: passo 1, immagine 1 di 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: passo 1, immagine 2 di 2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 3, immagine 1 di 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 3, immagine 2 di 2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 4, immagine 1 di 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 4, immagine 2 di 2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 5, immagine 1 di 1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Battery: passo 6, immagine 1 di 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Battery: passo 6, immagine 2 di 2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 7, immagine 1 di 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 7, immagine 2 di 2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 8, immagine 1 di 1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 9, immagine 1 di 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 9, immagine 2 di 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 9, immagine 3 di 3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
  10. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: passo 10, immagine 1 di 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: passo 10, immagine 2 di 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement, Motherboard: passo 10, immagine 3 di 3
    • Remove the 3.15mm Phillips Head #000 screws from motherboard.
  11. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 11, immagine 1 di 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 11, immagine 2 di 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 11, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the two ribbon cables by gently lifting on the black hinges and pulling away with tweezers
  12. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 12, immagine 1 di 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 12, immagine 2 di 2
    • Gently disconnect the rear-camera connector
  13. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 13, immagine 1 di 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 13, immagine 2 di 2
    • Gently remove the front-facing camera by gently lifting on the connector tab.
    • Remove the other connector by gently lifting with a spudger.
  14. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 14, immagine 1 di 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 14, immagine 2 di 2
    • Pry off the plastic brace along the top edge of the phone
  15. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 15, immagine 1 di 2 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 15, immagine 2 di 2
    • Remove the antenna connected to the bottom piece of the screen plate
  16. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 16, immagine 1 di 1
    • Gently lift the motherboard off the frame
    • Pull the camera out from behind the motherboard
  17. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 17, immagine 1 di 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 17, immagine 2 di 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 17, immagine 3 di 3
    • Using a spudger, disconnect the charging port assembly cable and the screen connection cable.
    • Remove the motherboard completely.
  18. Lenovo Vibe Z2 Pro Charging Assembly Replacement, Charging Assembly & Headphone Jack: passo 18, immagine 1 di 1
    • Remove the 3.6 mm Phillips head screws from the charging assembly
  19. Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 19, immagine 1 di 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 19, immagine 2 di 3 Lenovo Vibe Z2 Pro Charging Assembly Replacement: passo 19, immagine 3 di 3
    • Gently peel the flat cable away from the screen
    • Gently lift the charging assembly using a spudger
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 18-3, Blackwell Fall 2016 Membro di USF Tampa, Team 18-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,028
