Salta al contenuto principale
Lenovo Touch Y70-70 RAM Replacement
Cosa ti serve
  1. Lenovo Touch Y70-70 RAM Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 RAM Replacement: passo 2, immagine 1 di 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 RAM Replacement, RAM: passo 3, immagine 1 di 2 Lenovo Touch Y70-70 RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Use your fingers or two of the blue Opening Tools to lightly pull the tabs away from the RAM to free the first stick.
    • Remove the first stick and and do the same thing to the second RAM stick.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 305
