Salta al contenuto principale
Introduzione
Use this guide to remove the RAM (random access memory) from your device.
Strumenti
Nessun attrezzo specificato.
  1. Remove the battery by sliding forward the switch here.
    • Remove the battery by sliding forward the switch here.
    • For more info on how to remove the battery, refer to battery replacement guide.
  2. The RAM is the small square component on the back. Unscrew all screws using a diamond head screw.
    • The RAM is the small square component on the back. Unscrew all screws using a diamond head screw.
    • There are only two screws to remove as circled here.
    • The screw head used here is a JIS J00 Driver.
  3. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  4. On the edges of the RAM components, push each switch to the side.
    • On the edges of the RAM components, push each switch to the side.
    • The RAM chip should pop up on its own once you push each side outwards.
  5. The RAM chip should pop up on its own once the sides are pushed outwards. Gently pull on the RAM to remove.
    • The RAM chip should pop up on its own once the sides are pushed outwards.
    • Gently pull on the RAM to remove.
  6. Remove the RAM from the device.
    • Remove the RAM from the device.
Conclusione
Peter Gachuki
Membro da: 26/03/2018
576 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 222
