Salta al contenuto principale
Introduzione
This guide will take you through how to replace the keyboard in your Lenovo ThinkPad X201 Tablet if it is broken or damaged.
Parti
Nessuna parte specificata.
  1. First you push the lock button on the back of the computer from lock to unlock.
    • First you push the lock button on the back of the computer from lock to unlock.
  2. Then you hold it on unlocked and slide the battery pack out.
    • Then you hold it on unlocked and slide the battery pack out.
  3. Kits di riparazione iPhone X
    Garanzia finita? Non preoccuparti, abbiamo la soluzione.
    Acquista ora
    Acquista ora
  4. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
    • Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
  5. Using your fingers push keyboard forward so it is closer to the screen than it was before
    • Using your fingers push keyboard forward so it is closer to the screen than it was before
  6. Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
    • Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
Conclusione
Thomas Donahue
Membro da: 20/03/2018
470 Reputazione
2 Guide realizzate
Excellent.. thank you.. I just put on my new keyboard. I appreciated seeing your photos just to make sure I didn’t miss anything.
Andy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 664
