Introduzione
For this guide, you'll need to use a metal spudger to remove the individual keys from the keyboard. You can also use a plastic opening tool to remove the keys as well.
Parti
Nessuna parte richiesta.
  1. Turn off laptop by pressing the power button.
    • Turn off laptop by pressing the power button.
  2. Use a metal spudger or a flat head screwdriver to pry up the desired key.
    • Use a metal spudger or a flat head screwdriver to pry up the desired key.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Again with the pry method, pry up the below component below the key.
    • Again with the pry method, pry up the below component below the key.
  5. Grab and pickup the square shaped component. This is the part that you can clean out.
    • Grab and pickup the square shaped component. This is the part that you can clean out.
Conclusione
Peter Gachuki
Membro da: 26/03/2018
558 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 335
