Salta al contenuto principale
Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement
Cosa ti serve
  1. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Bottom Panel: passo 1, immagine 1 di 2 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: passo 2, immagine 1 di 1
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Speakers: passo 3, immagine 1 di 3 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Speakers: passo 3, immagine 2 di 3 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Speakers: passo 3, immagine 3 di 3
    • Carefully unplug the speaker connector by pulling it towards you.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: passo 4, immagine 1 di 2 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: passo 4, immagine 2 di 2
    • Remove the two 5 mm screws on each speaker with a Phillips #1 screwdriver.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: passo 5, immagine 1 di 2 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: passo 5, immagine 2 di 2
    • Unweave the blue and white wires from underneath the plastic tabs connected to the battery.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: passo 6, immagine 1 di 1
    • Lift each speaker up and out from the computer.
Conclusione
Cal Poly, Team S1-G4, White Winter 2020 Membro di Cal Poly, Team S1-G4, White Winter 2020
CPSU-WHITE-W20S1G4
3 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 43
Tutti i Tempi: 2,241
