Introduzione
This guide will help you remove the speakers from your Lenovo Thinkpad Twist s230u. The speakers are what your computer uses to play audio, so you will probably notice if there is something wrong with them quickly. Good speakers generally last a long time (usually longer than you will keep your device for), but there is always a possibility that your speakers could go bad. If you need to replace your speakers, this guide is for you. For more information on diagnosing problems you may have, visit our troubleshooting page.
Cosa ti serve
Flip the laptop over.
Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
Flip your device over.
Use the Phillips #1 screwdriver to remove the nine screws.
Flip the laptop cover over.
Using a Phillips #1 Screwdriver, remove the four screws holding the speakers in.
