Salta al contenuto principale
Lenovo Thinkpad Twist s230u Speaker Replacement
Cosa ti serve
  1. Lenovo Thinkpad Twist s230u Speaker Replacement, Hard Drive: passo 1, immagine 1 di 2 Lenovo Thinkpad Twist s230u Speaker Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Flip the laptop over.
    • Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
  2. Lenovo Thinkpad Twist s230u Speaker Replacement: passo 2, immagine 1 di 1
    • Using the iFixit Opening tool, loosen the hard drive cover.
  3. Lenovo Thinkpad Twist s230u Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the hard drive cover.
  4. Lenovo Thinkpad Twist s230u Speaker Replacement: passo 4, immagine 1 di 2 Lenovo Thinkpad Twist s230u Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the hard drive by sliding it out.
  5. Lenovo Thinkpad Twist s230u Speaker Replacement, Keyboard: passo 5, immagine 1 di 1
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  6. Lenovo Thinkpad Twist s230u Speaker Replacement: passo 6, immagine 1 di 1
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  7. Lenovo Thinkpad Twist s230u Speaker Replacement: passo 7, immagine 1 di 1
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  8. Lenovo Thinkpad Twist s230u Speaker Replacement: passo 8, immagine 1 di 3 Lenovo Thinkpad Twist s230u Speaker Replacement: passo 8, immagine 2 di 3 Lenovo Thinkpad Twist s230u Speaker Replacement: passo 8, immagine 3 di 3
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
  9. Lenovo Thinkpad Twist s230u Speaker Replacement, Upper Casing: passo 9, immagine 1 di 1
    • Flip your device over.
    • Use the Phillips #1 screwdriver to remove the nine screws.
  10. Lenovo Thinkpad Twist s230u Speaker Replacement: passo 10, immagine 1 di 2 Lenovo Thinkpad Twist s230u Speaker Replacement: passo 10, immagine 2 di 2
    • Flip the device back over and open the top.
    • Use the Phillips #1 screwdriver to remove the seven silver screws.
    • Disconnect the three cables inside the case.
    • Lift up the brown tab and disconnect the ribbon cable.
  11. Lenovo Thinkpad Twist s230u Speaker Replacement: passo 11, immagine 1 di 2 Lenovo Thinkpad Twist s230u Speaker Replacement: passo 11, immagine 2 di 2
    • Close the lid and turn the device around.
    • Use the iFixit Opening Tool to lift up and remove the tab on the back.
  12. Lenovo Thinkpad Twist s230u Speaker Replacement: passo 12, immagine 1 di 2 Lenovo Thinkpad Twist s230u Speaker Replacement: passo 12, immagine 2 di 2
    • Turn the device back around and reopen it.
    • Use the iFixit Opening Tool to disconnect the top of the case from the bottom.
    • Lift up the top of the case and slide it out from under the screen.
  13. Lenovo Thinkpad Twist s230u Speaker Replacement, Speaker: passo 13, immagine 1 di 2 Lenovo Thinkpad Twist s230u Speaker Replacement, Speaker: passo 13, immagine 2 di 2
    • Flip the laptop cover over.
    • Using a Phillips #1 Screwdriver, remove the four screws holding the speakers in.
  14. Lenovo Thinkpad Twist s230u Speaker Replacement: passo 14, immagine 1 di 1
    • Remove the speakers from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 260
