Salta al contenuto principale
Lenovo Thinkpad Twist s230u Keyboard Replacement
Cosa ti serve
  1. Lenovo Thinkpad Twist s230u Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  2. Lenovo Thinkpad Twist s230u Keyboard Replacement: passo 2, immagine 1 di 1
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  3. Lenovo Thinkpad Twist s230u Keyboard Replacement: passo 3, immagine 1 di 1
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  4. Lenovo Thinkpad Twist s230u Keyboard Replacement: passo 4, immagine 1 di 3 Lenovo Thinkpad Twist s230u Keyboard Replacement: passo 4, immagine 2 di 3 Lenovo Thinkpad Twist s230u Keyboard Replacement: passo 4, immagine 3 di 3
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,128
