Salta al contenuto principale
Lenovo Thinkpad Tablet 1838 Touch Screen Replacement
Cosa ti serve
  1. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement, Touch Screen: passo 1, immagine 1 di 1
    • Remove the button with the arrow pointing left.
    • You can do this by putting the spudger underneath the button and pulling up.
  2. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: passo 2, immagine 1 di 1
    • Remove the two 10mm Phillips #00 screws.
  3. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: passo 3, immagine 1 di 1
    • Use an opening tool to pry open and disconnect the screen from the rest of the tablet.
    • Be gentle and work from the bottom of the tablet in counterclockwise direction.
  4. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: passo 4, immagine 1 di 1
    • Open the tablet screen to the left, making sure not to disconnect any of the wires connecting the screen to the tablet.
  5. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: passo 5, immagine 1 di 2 Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: passo 5, immagine 2 di 2
    • Disconnect the ribbon connector by pulling up on the white gate.
    • Then just simply pull the wire to the left to disconnect it.
  6. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: passo 6, immagine 1 di 2 Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: passo 6, immagine 2 di 2
    • Disconnect the last ribbon connector using your fingernails to grip the ends of the connector and gently pull to the left.
    • There might be some tape over the connector that you will have to remove.
  7. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: passo 7, immagine 1 di 1
    • You have successfully removed the old screen.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 751
